Drilled/Slotted Rotors Help!
Old Apr 1, 2008 | 05:56 PM
turbo kraut's Avatar
Tech Guru
Default RE: Drilled/Slotted Rotors Help!
ORIGINAL: Got2Speed
no problem dude i do it all the time[&:].....but guys with this am i going to need new callipers and all that crap?
plus what would you guys reccomend for rear rotors?
i did attach the a8 for the 2.6 fwd....... just got to purems.com, and sellect your vehicle
as for rears...... http://www.purems.com/products/products.php/CA=1441
that is for the 01 1.8t.... 36 bucks... want better looking at about 200
all that is stock... well a8 rotors, tt carriers a4 calipers(painted red)
Old Apr 1, 2008 | 05:57 PM
Tech Guru
ORIGINAL: kaklexicon
ON this subject.. Is it true that drilled/slotted rotors cause alot more dust and wear down your break pads quicker?
*no intentions of hijacking just a quick question
you will probably get more dust, but slotted and cross drilled will wear out quicker and crack....... if you get your rotors too hot
Old Apr 1, 2008 | 06:05 PM
Got2Speed's Avatar
aiight thanks alot turbo kraut[&:]
Old Apr 1, 2008 | 06:09 PM
chaos92287's Avatar
makes sense but i dont know for sure. there's a big debate about which is best. drilled/slotted/dimpled are supposed to dissapate heat but they also make less contact area and weaken the rotor. unless your generating a crapton of heat (something like autocross) blanks are definitely better.
also here's something to consider. f1 cars use blanks w/ ceramic pads
Old Apr 1, 2008 | 06:14 PM
bolob5's Avatar
Well as far as the drilled and slotted rotors they are better for heat dissipation. Like stated earlier in this thread they would probably be for more track use than anything else. I agree with everyone else in your case, go with the A8/TT setup. Might want to grab some steel braided lines to get a better pedal feel if you plan on auto crossing or the occasional track use…
As for me I would go with the ECS Zimmerman rotors, red top pads, steel lines, and some fresh brake fluid… Then again my Brembo setup on my 98 is VERY NICE, TOO MUCH.
Old Apr 1, 2008 | 08:20 PM
skills@eurocarsplus's Avatar
i have brembo drilled rotors and EBC pads on the front and rear of my A4, little dust (i mean, very little) and will throw you through the windshield. best 250.00 i spent on the car
Old Apr 1, 2008 | 09:24 PM
1.8TK3MP's Avatar
ORIGINAL: turbo kraut
get a8 kit with tt carriers from pure for 249....... you really don't need rear rotors.........
http://www.purems.com/products/products.php/CA=1440
why does it look as if your fmic is outside the bumper?
Old Apr 1, 2008 | 09:29 PM
  #18
Got2Speed's Avatar
cause he doesnt have a bumper....
Old Apr 1, 2008 | 10:31 PM
  #19
ImTheDevil's Avatar
Agreed with everyone else - stock rear rotors are more than enough. Do the A8/TT kit for the front - you won't regret it. They work incredibly well, and they look great too This is them, filling up my 17" wheels:
I know what the other guys are saying about the drilled/slotted rotors, and I don't track my car, but I got them for a different reason. In the rain, my brakes sucked badly - it was like I had air in the lines. I suspected the pads were floating off the rotors and hurting my braking performance. I got the drilled/slotted rotors in the hopes that the fading brake feel in the rain would disappear. It has. And these things stop like a brick wall. It's not on par with StopTech or Wilwood, but then, this whole kit with Hawk pads and shipping cost about as much as a StopTech rotor. I'm 100% happy.
Old Apr 2, 2008 | 08:49 AM
  #20
CampbellsChunkySoupr's Avatar
so if you do the A8 upgrade: there are slotted/drilled rotors available for upgrade for that setup?
will the A8 upgrade fit my stock wheels on my 01 a4 a.8Tmq sport package?
