drive shaft removal
Old Aug 27, 2009 | 06:22 PM
das_grcygttr's Avatar
Default drive shaft removal
this may be a dumb question. but i went underneath my car and made an attempt to replace the cv joint on my drive shaft, i could not seem to figure out how to remove it. i unscrewed the 6 allen bolts and thought i could slide it out of the transmission.....i was wrong. Does anyone know what i need to do or have a link to show me how to do it. I drive a 99 a4 1.8t avant. thanks in adavnce for your help
Old Aug 30, 2009 | 02:07 AM
bump for some help
Old Aug 30, 2009 | 05:41 PM
Broncoman75's Avatar
a hammer or a prybar?
i havent had it apart from the trans, but removed it from the differential.
It was just kind of stuck to the diff by the grease and gasket in there... just try prying down on it
Old Aug 31, 2009 | 12:03 AM
Tweaked's Avatar
The axles like to stick to the flange. The flange stays in the trans while the coupling comes off the flange. Use a dead-blow to walk the coupling off the flange. They can be a pain. Sometimes soaking the flange edge with rust penetrate will help. As a last resort, tap a prybar around the coupling to break it free of the flange.
Old Sep 1, 2009 | 01:43 AM
thanks ill see what i can do
trace66usa
May 3, 2015 04:40 PM
sillyd_71
Mar 12, 2015 11:57 AM
kbevere
Oct 14, 2010 09:36 AM
davisbr9
Feb 10, 2010 01:00 PM
Rdcarter
Oct 18, 2009 07:39 PM
