Dtc p0171
My daughter just bought a 2001 A4 w/1.8T. In a couple of weeks it threw a P0171. I searched here and most suggested a new MAF. I got impatient waiting for one to arrive and cleaned the existing one and reset the code. So far so good. I tossed the PO's K&N filter and put a paper one in instead.
I also changed the oil to Redline 10w-40 (which does not seem too popular here). Removing the old filter was not the most fun I have ever had working on a car since I did not have a filter wrench to fit it. 460 Channel locks were required to get it loose.
There sure is a lot of plastic on these cars!
Lou
Lou
What you might try is drying out the K&N filter. Our cars are sensitive and if the filter has excess oil on it (they're oiled to help with filtration), it can get sucked into the engine. If it hits the MAF element on the way, it'll freak out the MAF and usually toss a code as a result. The K&N is a great filter to run - try dyring it out some and reusing it. If you do that and the code doesn't reappear, that was the cause.
In my opionion there is no free lunch. A K&N reduces inlet losses by providing a less restricitive air flow path. In my mind that means bigger chunks get by, not a good deal for long term engine life. I don't dispute the K&N is a good deal, but I don't want to risk the long term effects.
Lou
Lou
yea Devil.. i just had my MAF go bad (p0102) code.. and i got a new MAF and it fixed it fine.. im also running a K&N but its an actual cone filter intake.. i let it dry out a little before i installed it which was like, in the late summer.. Aug/Sept.. im hoping my MAF was just ready to go since it was the original one.. maybe should just make a routine to clean my filter assembly every other oil change or something and clean my MAF as well huh?
Lou
Lou
at 170k miles if you are still on the origional MAF that is a very good lifetime. usually you can expect 80-120k miles out of them.
