DVV fluttering never herd it before.
Old Mar 13, 2008 | 07:57 PM
BoostnB5's Avatar
Default DVV fluttering never herd it before.
I have a 2001.5 1.8t with a forge 007 dvv. I also have a godspeed fmic. When the dvv opens to reciculate the air to the piping instead of the steady shhhh i usually get, the air flutters and starts to sound like an hks ssq. It just resently started ive had both the dvv and the fmic on for over a year, could the dvv be going bad?spring worn?needs to be cleaned maybe? any help would be appreciated. thanks.
Old Mar 13, 2008 | 08:06 PM
cincyTT's Avatar
I'm make believe
Default RE: DVV fluttering never herd it before.
First, what is the second V for? Its diverter valve (dv).
If you are talking about with low boost (5-8psi), it is normal. You should be running either a green spring with 2 shims or just the yellow spring. The green with 2 shims seems to work best with most.
Old Mar 13, 2008 | 08:12 PM
BoostnB5's Avatar
Sorry cincytt i got key happy ,long day at work. it has a green spring and two shims but it also does it on 10-15psi, im gonna clean it tommorow anyway when i clean my car and check all the lines and couplings going into it too as well to make sure nothing came loose.
Old Mar 13, 2008 | 08:19 PM
cincyTT's Avatar
I'm make believe
You can grease up the pistonand swap in the yellow spring and see how it works for you then.
Old Mar 13, 2008 | 09:09 PM
BoostnB5's Avatar
ill try that too tomorow thanks again.
silverttq
Sep 11, 2008 01:32 AM
Blue01TT
Aug 29, 2008 02:29 PM
SickRS4
Apr 1, 2008 06:53 PM
a4fanatic82
Jun 27, 2007 09:06 PM
