BOV Fluttering
Old Aug 29, 2008 | 12:52 PM
Blue01TT's Avatar
Default BOV Fluttering
I got the bov in and its sounds great. At higher rpms it has a slight flutter but in the lower rpms it flutters really bad. Do I need to harden the spring to get rid of flutter or soften the spring I haven't really messed with it a whole lot yet because I didn't wanna do to much before asking. At peak boost it makes a real quick flutter then full release like pssh pppsssssshhhhhh is that okay or should there be NO flutter at all. BTW the valve is greddy type rs w/ anti stall attachment.
Old Aug 29, 2008 | 01:42 PM
Wintermute's Avatar
You might be backspinning your turbo. Check your vac lines.
Old Aug 29, 2008 | 01:43 PM
Wintermute's Avatar
Take a photo of your install we can better help you if we see what you've done.
Old Aug 29, 2008 | 01:57 PM
cincyTT's Avatar
I'm make believe
Thats not possible, i think you mean slowing. But still not it. I sounds like it needs softened. Most valves will have some fluttler at 5psi when you are running 20+ psi since its hard to adjust for both. Some valves like the HKS SSQV have 2 adjustments that keep it from doing that. Not sure if the GReddy does or not, i know they have a dual vac line in the back
Old Aug 29, 2008 | 02:29 PM
Wintermute's Avatar
Anything is possible that's why I said take a photo so we can see. It could be a simple confusion of the lines.
silverttq
Sep 11, 2008 01:32 AM
BoostnB5
Mar 13, 2008 09:09 PM
DragonStar4681
Feb 16, 2008 10:28 PM
prbayha
Sep 22, 2007 10:30 PM
a4fanatic82
Jun 27, 2007 09:06 PM
