ECU / VCDS problem
Old Sep 8, 2012 | 02:47 PM
Sastrugi's Avatar
Default ECU / VCDS problem
Hi everyone,
I have a '99 A4 1.8. After switching out an old battery the other day, it was idling rough and low, eventually stalling. If I depress the accelerator it will work for a fraction of a second and then cut out as though I had lifted my foot up. My initial thought was that I messed up the ECU so I unplugged it for an hour and went through the reset procedure. This did not fix the problem so I bought a 3rd party OBD cable and connected it up to my car. I had done this before years ago and was able to fix this problem by resetting fault codes. The strange thing is that this time I was only able to connect to several modules. Here is the report it gave me.
Address 08: Auto HVAC
Protocol: KW1281
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLL
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Protocol: KW1281
Controller: 8D0 919 910 P
Component: B5-KOMBIINSTR. VDO D05
Coding: 02242
Shop #: WSC 00000
Address 35: Centr. Locks
Protocol: ????
Controller:
Note: Can't Synch Baud Rate
Address 45: Inter. Monitor
Protocol: KW1281
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 06325
Address 56: Radio
Protocol: KW1281
Controller: 4B0 035 186 A
Component: Radio D02
Coding: 00201
Shop #: WSC 06325
Any help would be greatly appreciated.
Thanks!
Pete
Old Sep 8, 2012 | 07:07 PM
mtroxel's Avatar
My guess is you have a problem with your computer set up, the line your using to your interface or the interface itself. If you go to the Options button in VCDS and test your com port, I think it tells you whether the comm rate is poor, fair, good, etc. Is yours "poor"?
Old Sep 9, 2012 | 05:58 PM
Sastrugi's Avatar
You're right, it says "poor". Maybe I can get it to work with the updated VCDS software instead of the version that came with the cable.
Old Sep 9, 2012 | 10:56 PM
mtroxel's Avatar
It's not the software, it's the hardware. Are you using a serial port...or a USB to serial adapter? That will give you crappy throughput.
Old Sep 12, 2012 | 01:47 PM
Sastrugi's Avatar
So I tried a reader instead of my lame cable and I still was not able to access the engine. I did notice that it listed the status of my oxygen sensor as "inc" which I'm guessing stands for inconclusive. It could be that the sensor is trashed and is interfering with the calibration. It's a bit of a gamble just going out and buying one though as they are pretty expensive. Maybe I'll hit the dump and look for B5s.
JCaratini
B8 Models
Feb 16, 2015 08:37 PM
maximedelo
Jan 21, 2014 08:01 AM
tofast2belast
Mar 2, 2013 07:37 AM
binco
Feb 1, 2013 10:25 AM
krazzz
Feb 21, 2011 08:41 AM
