Electrical problem
Old Apr 7, 2010 | 08:54 AM
willie7182's Avatar
Default Electrical problem
Need a little help guys...
Unfortunately I hooked up the battery with my darn ignition on -eeek! The ECU is fine, but something else isn't. My vag com cannot communicate with the car so it's difficult to tell what is wrong. Here is what happens when I turn the key:
Check engine light is on but not steady. The tach bounces. oil, gas, and coolant lights flash but aren't consistent. There is a clicking noise from what looks like a solenoid next to the intake on the top side of the engine.
Battery power is fine and I swapped two different ECUs to be certain this isn't the problem.
A4 electronics is not my forte!! where do I go from here?
Old Apr 7, 2010 | 10:19 AM
kevace1's Avatar
I would definitely check the ICM, and all relays pertaining to it, if any. Does your car run if you crank it? What motor?
Old Apr 7, 2010 | 12:54 PM
willie7182's Avatar
I will look into the ICM and relays. They should all be behind the ignition cylinder right?
It's a 2.8L. When I try to crank it nothing happens... Everything goes dead.
DurTTy
Oct 5, 2007 03:41 PM
steelcitysfinest69
Jul 24, 2007 01:42 PM
tbr76
Jan 13, 2007 02:14 PM
miabhai_freaked
Feb 22, 2006 11:12 PM
