Engine Light After Chipping
Old Jan 30, 2009 | 02:42 AM
425macchi's Avatar
Member
Default Engine Light After Chipping
Check Engine Light After Chip Install
2002 B5 S4 45xxx
I need help figuring out what this is before I take it in, if I do...
My engine light came on and recieved the following fault code when scanned. I had hust had a temperary APR Chip Upgrade Installed. For all who dont know, its basically a trial version good for 6 hours so you can love the result and spend the $600 to buy the permanent one.
Fault code 17585 "Bank 2 lamda correction downstream of Catalyst; control limit attained"
I had the code cleared and the temp chip has expired. The check engine light has not come back and it has been 2 days.
Can anyone help me figure this out please? Maybe bad cat? or o2 sensor?
Old Jan 30, 2009 | 02:48 AM
A4speed's Avatar
sometimes the ecu will correct whats wrong and if your check engine light doesn't come back on then your good.
if it does i would guess the 02 sensor or a boost leak.
Old Jan 30, 2009 | 08:37 AM
RyanSweeney's Avatar
I got a CEL last night too...actually, I'd gotten a CEL a week before I sent off my ECU to be tuned, but I added a couple of spark plug non-foulers to the rear O2 sensor and within 10 miles of driving, the CEL went off.
Sent off my ECU...got it back on a Friday, and then last night (Thursday), I went to start my car...took 3 times to start it, and the CEL stayed on once it was running.
Old Jan 30, 2009 | 12:46 PM
FASTER's Avatar
Tech Slut
2002 B5 S4 45xxx
just to let you know for future reference, there is a section for S-cars... they can help you out alot better than us A4 guys...
Old Jan 30, 2009 | 11:44 PM
chaos92287's Avatar
if the code doesn't come back, your fine. maybe the chip made you run too rich and caused a carbon build up that has since gone away. if it comes back, its probly the cat or maybe the sensor. if you had an o-scope you could check the sensor
Old Jan 31, 2009 | 03:27 AM
425macchi's Avatar
Member
My bad for posting in the wrong section. I saw B5 on a link and clicked it and didnt realise this was the A4 section till the next day. By you guys have actually been more helpful, thanks!
Old Jan 31, 2009 | 08:03 AM
ImTheDevil's Avatar
Glad it's paying off Several other S4 guys post in here a lot and overall there are enough similarities that for most of your problems, the A4 section will be able to help.
BTW, I agree that if you continue to see the code it's likely related to your driver's side post-cat O2 sensor.
cipi888
Jul 16, 2013 05:11 PM
playboy00786
Jan 27, 2008 08:39 PM
blanthony
Mar 25, 2006 01:18 PM
