Engine Misfire!! Help!!
Old Apr 19, 2008 | 02:46 AM
RAZ301's Avatar
Default RE: Engine Misfire!! Help!!
im having the same problem bro. i changed all the air censors, fule filter, spark plugs (i got some cheap one cuz i ran out of cash) i will be geting new ones tomorrow. i think our problem will be resolved if we buy the sparkplug cables. let me know if you fixed the problem. i will do the same.
Old Apr 19, 2008 | 12:00 PM
Dropshotdude's Avatar
OK, so I figured out the problem...as I was changing my spark plugs to the new ones, I changed them and put the new ones in...after I put them in it ran worse and I was befuddled. I didn't bolt the coil packs down as I changed the spark plugs and I realized that I could jiggle my coil packs and the motor would change how it ran. I unplugged all of the packs and saw that as I unplugged one of the coil packs, the car didnt run any worse....turned out my #3 coil pack was bad (even though It was brand new and I changed it less than a week before). I put my an OLD coil pack in there, from my original set and the car ran great. This being said, always check something twice, even though you think it's good. Glad I figured this out before I bought thousands of dollars of new parts to figure out that the problem was right under my nose....hope this helps!
Thanks to everybody for their help. It was priceless in figuring out my problem
Old Oct 8, 2008 | 11:32 PM
mott6904's Avatar
did you clear the codes. You had a code for the throttle position control malfunction. You need to have the throttle body reset
BHAudi
Jan 8, 2010 02:56 PM
TuApesta
Oct 22, 2008 03:09 PM
gsa4
Jul 30, 2007 03:37 PM
Henlow1
Jan 29, 2006 05:24 PM
dwkent
Apr 15, 2005 07:12 PM
