Engine not running 100%
Old Nov 28, 2012 | 07:21 AM
TUC's Avatar
TUC
Default Engine not running 100%
Hi Guys'
I have a little problem with my 2000 A4 1.6 Petrol. The problem is when i start my car its fine for a few minutes untill it warms up,then it starts to run rough and when i come to a set of traffic lights or something similar its as if its gonna cut out, then when i start off again it give a splutter before it goes again!!..Any Help??
Old Nov 28, 2012 | 08:43 AM
CCA4's Avatar
When's the last time it had a tune up? Fuel filter, spark plugs, air filter, etc.
Old Nov 28, 2012 | 10:47 AM
TUC's Avatar
TUC
Hi, sparkplugs and air filter have been changed recently but i don't know about the fuel filter!
Old Nov 28, 2012 | 12:34 PM
CCA4's Avatar
How many miles/kms on the car? I'd bet yours is original. Relatively easy job to change it, I'd slap a new one on there and see if that helps.
Old Nov 29, 2012 | 07:23 AM
TUC's Avatar
TUC
160 miles on it, gonna get a new filter today and try it, can't do any harm!! thanks for the response i will let ya know how i get on
Old Nov 29, 2012 | 07:33 AM
jonbonesjones's Avatar
Moderator
Try some seafoam in the gas aswell. Should sparkle the internals up a bit.
Old Nov 29, 2012 | 08:25 AM
CCA4's Avatar
160,000 or 160? o_O
When you change it, don't bother ******* around with the stupid clamp thing that holds it on. Once you get the banjo bolts good and tight, just jam it back up beside the gas tank. When you re-tighten the tank straps it will be in there good and snug, should shave at least an hour off the job. If you hit anything hard enough to knock it loose you're gonna have bigger problems
Old Nov 29, 2012 | 07:54 PM
mtroxel's Avatar
I mangled the clamp when I had to cut mine off with a hacksaw blade to get it off. I just put it back on with a nylon zip tie thing.
Old Nov 29, 2012 | 11:06 PM
ImTheDevil's Avatar
Are you modified at all? Verify that if your ECU is stock, that the new plugs are at .032", and if you're chipped, they're at .028". Also, pull your coil packs and look in the plug bores for oil. Leaking inner valve cover gaskets can let oil seep under the coil boots and cause a weakened spark.
Old Nov 30, 2012 | 07:19 AM
Moderator
Can you mod a 1.6 ?
