Engine problem?
Old Dec 1, 2009 | 04:07 PM
NickBroderick's Avatar
Default Engine problem?
During acceleration and starting my car, she makes a growling throaty sound, coming from the engine bay, towards the back. That's where it sounds like it's coming from while inside the car. I have no CEL, and the performance doesn't seem to be hindered. Everything seems ok aside from this noise. Almost sounds like a hole in the exhaust, that sort of sound. I have a video of it, I'll try and upload it. Any ideas what it could be? Just got my oil changed a couple weeks ago, if that means anything.
Edit: Here's the video. It's from my BlackBerry, so the quality isn't good.
I just took this video 3 minutes ago.
Old Dec 1, 2009 | 04:55 PM
bradtyler02's Avatar
I think you might be right, hole in the exhaust, or, perhaps one the the gaskets is leaking...
Old Dec 1, 2009 | 04:57 PM
I don't think it's a hole in the exhaust, my brother had that happen to his car and it was extremely loud, even at idle. It isn't coming from that area either, although I could check it out.
Old Dec 1, 2009 | 05:01 PM
If you haven't seafoamed in awhile, you could give that a try. If you have an exhaust leak, you would be able to see the smoke coming out of any leaks...
tried to listen to the vid, but all I could hear was your blinker...
Old Dec 1, 2009 | 05:07 PM
Sorry, it's after I take the turn, you can only hear it for a second then the mic can't pick it up anymore. I'll try and take a better video in a couple minutes. I've never actually done the seafoam, I heard it does amazing things. I didn't see any smoke anywhere, I'm 99.9% sure it isn't the exhaust.
Old Dec 2, 2009 | 10:57 AM
Drove it again late last night, I think the cold makes it worse. It was 31 degrees and embarassingly loud, at least inside the car.
Old Dec 2, 2009 | 11:33 AM
Alright. I found the problem. It IS the exhaust. Excellent. Now I can get that fixed asap.
spyrosg7
Apr 4, 2010 07:48 PM
audiq7
Audi Q7
Dec 16, 2009 08:14 AM
brownrice
May 10, 2007 08:38 PM
nooch914
Dec 28, 2005 05:02 AM
ndiego75
Sep 28, 2005 08:43 PM
