Engine spec ?
Old Apr 22, 2010 | 09:41 PM
lolo22's Avatar
Default Engine spec ?
I bought a 98 1.8t that had a replacement motor put in. I was wondering how I could tell if its the 150hp motor or the 170hp.
Old Apr 22, 2010 | 10:03 PM
MartinCieslak1's Avatar
what engine code? the early AEB are 150hp
Old Apr 22, 2010 | 10:08 PM
chocalotstarfish's Avatar
Super Moderator
If the car had a motor swap it should have came with papers stating mileage at swap and what year the swap was out of. If not, you just bought a motor that could have 200k+ miles! 2001 was the change. Easy way like stated is look at engine code.
Old Apr 22, 2010 | 10:09 PM
A4Cragman's Avatar
There should be a stamp on the block that says if its AEB, ATW or AWM. Like Martin said, the AEB is the 150, the other two are your 170 options.
Old Apr 22, 2010 | 10:16 PM
Nevalite's Avatar
Wait my 2000 1.8T QM with ATW is 170hp?
Old Apr 22, 2010 | 10:48 PM
lolo22's Avatar
Thanks I will look at the block, I have the receipt for the engine, It was put in at 69,000 didnt even think about looking at the receipt. I thought it changed mid 98 thats why I was curious.
Old Apr 22, 2010 | 11:25 PM
kriptonik's Avatar
ATW is 150HP. Only the AWM has the 170HP due to the K03S.
Old Apr 23, 2010 | 12:56 AM
FASTER's Avatar
Tech Slut
Originally Posted by A4Cragman
There should be a stamp on the block that says if its AEB, ATW or AWM..
its actually stamped on the head... there were only 2 blocks in those years, 058 and 06A
Old Apr 23, 2010 | 09:16 AM
dragonrage's Avatar
The difference is in the amount of boost. Those engines will make basically the same power if you don't swap ECUs.
Old Apr 23, 2010 | 12:55 PM
A4Cragman's Avatar
Ah. Thanks for clearing that up. I'm a 2.8 guy, a lot of details regarding the 1.8t I'm more or less a complete nub at. I was basing my info off the "engine code identification" sticky and thus assumed that it was the block that had the stamp and that it was either of the non AEB codes that had the extra ponies.
