Engine Sump/Pan Replacement
Old Jan 27, 2015 | 04:59 AM
mwabask's Avatar
Default Engine Sump/Pan Replacement
Hallo,
I wanted to find out if it possible to use an engine sump/pan from a 1996 Audi A4 in a 2000 Audi A4? Can it work without complications?
Will appreciate your comments and advice.
Old Jan 27, 2015 | 10:52 AM
MetalMan's Avatar
Welcome to AudiForums!
First off, we need to know which engine you are referring to.
If you are referring to the 1.8T : the 2000 1.8T (engine code ATW) has an oil level/temperature sensor at the bottom of the oil pan, and the 1996 1.8T (engine code AEB) does not have this. Therefore it will not be compatible.
Old Jan 28, 2015 | 08:03 AM
mwabask's Avatar
Default Engine Sump/Pan: 1996 Audi A4 and 2000 Audi A4
Thanx for the reply.
My Audi engine code is : APU not sure about the other Audi.
Old Jan 28, 2015 | 11:03 AM
MetalMan's Avatar
From a quick search it sounds like the APU is a European 1.8T. In the U.S. we received engine code AEB instead of APU, but my guess is they are similar with respect to the oil pan.
Old Jan 29, 2015 | 08:19 AM
mwabask's Avatar
Thanks alot for the advice. Much appreciated.
tonyfelloni
B7 Models
Jul 4, 2014 10:04 AM
dustydave
Feb 19, 2014 06:10 AM
rustyleskiv
Apr 4, 2006 05:03 PM
faz
Jul 30, 2005 12:23 PM
Doose
May 11, 2004 01:06 AM
