Engine Sump/Pan Replacement
Hallo,
I wanted to find out if it possible to use an engine sump/pan from a 1996 Audi A4 in a 2000 Audi A4? Can it work without complications?
Will appreciate your comments and advice.
Welcome to AudiForums!
First off, we need to know which engine you are referring to.
If you are referring to the 1.8T : the 2000 1.8T (engine code ATW) has an oil level/temperature sensor at the bottom of the oil pan, and the 1996 1.8T (engine code AEB) does not have this. Therefore it will not be compatible.
