Engine wont turn.
Old Jun 12, 2010 | 09:56 PM
FASTER's Avatar
Tech Slut
Default Engine wont turn.
So I just put my engine setup back in my car, everything went pretty smooth minus a few small electrical issues. Anyhow, I went to start her up and the starter just clicked once. So I pulled the starter out and had a friend crank the ignition. The starter spun and moved outward just fine like its supposed to. So I then tried to cycle the engine by hand and it wouldnt budge, even with a breaker bar on the crank pulley and a ratchet on the cam gear pulley simultaneously.
So heres what i had apart, Took the cams out and put them back in to spec (16 teeth inbetween timing marks on each cam gear, 10nm torque on caps, oiled journals) After putting the head back together i cycled it on the cam pulley and it turned and clicked, pausing between each valve cycle, as I believe it should.
I then set both the pistons and head to tdc and did the timing and buttoned up the rest of the engine.
Anyone have any ideas? Thanks in advance.
Old Jun 12, 2010 | 10:43 PM
turbo kraut's Avatar
Tech Guru
no idea why, but email mike
he would be the best resource i would go to
Old Jun 13, 2010 | 12:11 AM
FASTER's Avatar
Tech Slut
I talked to him earlier. No dice I guess ill pull the head off n see what's up
Old Jun 13, 2010 | 04:44 PM
FASTER's Avatar
Tech Slut
So I pulled the VC and sure enough the intake cam wasn't aligned properly. No idea how this happened cuz I thought I aligned it all perfectly. But obv I was excited to finish it and rushed through that part. So should be up and running again when it stops raining.
Old Jun 14, 2010 | 10:53 PM
Tech Guru
good to hear.... video's after the fact please
Krolmariusz
Oct 9, 2012 03:33 PM
virris88
Oct 16, 2007 09:57 PM
naptownlax54
Sep 25, 2007 12:26 AM
mikeysentra
Nov 6, 2005 05:21 AM
