EPC Light on help?!
Old Sep 23, 2010 | 03:58 AM
Got01A4's Avatar
Default EPC Light on help?!
The problem with the car before is that it was automatically shutting down while driving and it was throwing P1419 code which was ECT sensor going bad, which I replaced that and it was working perfectly fine until about a month and the problem started happening again.
It should shut off and the EPC light would come on with the check engine light.
I'm thinking could it be a bad MAF? I disconnected the battery to try and reset the code but it went away for a day and the next day it started happening again.
What else could be wrong?
Thanks
Old Sep 23, 2010 | 08:02 AM
markymarc's Avatar
99% sure it's your MAF.....it can cause a complete engine shut down, hesitation etc....it contains a bunch of sensitive resistors, they heat up and as air flows by and cool.....
Old Sep 23, 2010 | 08:09 AM
markymarc's Avatar
my other 1% hahahahaha, what year is your car? Later models of B5s also have a MAP sensor, so your car would still run even if your MAF is bad.....so it could also be your throttle body, but replacing the MAF is cheaper than doing the whole throttle body....and it's a better guess on my part since they do occasionally fail....
Old Sep 23, 2010 | 04:35 PM
Got01A4's Avatar
Sorry, its an 01 A4 1.8t.
Old Sep 23, 2010 | 09:58 PM
markymarc's Avatar
Start with a new MAF......
Old Sep 23, 2010 | 10:55 PM
Msnickbroderick's Avatar
Actual WIZARD
unplug your maf, and try running mafless, its possible on the 01 and up. If it stops then its your maf
Old Oct 7, 2010 | 02:11 AM
Got01A4's Avatar
Havent gotten a chance to check out the MAF yet, but I did notice there is a slight hesitation when accelerating.
Old Oct 8, 2010 | 11:50 PM
Got01A4's Avatar
Replaced the MAF and like Keegan said I started the car and let it idle with the MAF unplugged and it turned off. So replaced the MAF and well see.
Old Oct 9, 2010 | 03:26 AM
Actual WIZARD
Thats odd, cause I got my 1.8 running enough to drive it N/A for a parts store run by running mafless. My guess is scan for codes and see if its your coolant temp sensor
Old Oct 9, 2010 | 04:03 AM
joenelson7687's Avatar
huh??
