Error Code P1559
Old Aug 29, 2008 | 07:54 PM
auditech79's Avatar
Because its the only course of action before proceeding.
Old Aug 29, 2008 | 07:57 PM
Jc61990's Avatar
yea, it will allow the cars computer to recalibrate its self. and did you at all change your idle speed via a usb vag-com?
Old Aug 29, 2008 | 08:00 PM
love the booB5's Avatar
SoCal Crew Member
Ok I'll give it a shot then. I haven't changed any settings with a VAG-COM.
Old Sep 2, 2008 | 07:35 PM
Superdug's Avatar
SoCal Crew Member/White Devil
hey guys just to join in. i did the vag work. So you think by resetting the computer it will work.
Old Sep 2, 2008 | 07:37 PM
Superdug's Avatar
Should we change any settings?
Old Sep 2, 2008 | 07:42 PM
auditech79's Avatar
Don't need to change any settings, i would double check to see if there is any carbon build up on the throttle body valve thats restricting the closing of the valve. Looking on the VAG COM the throttle valve angle shouldn't be more than 3% at idle. That value should be between data blocks 2-6.
Old Sep 2, 2008 | 08:11 PM
onepoint8tee's Avatar
Originally Posted by auditech79
Adapt what? The cable? The reason you adapt it is to tell the throttle body module how much the valve is open or closed.
I would just erase the fault code and see if it comes back.
I thought adaptations realign the TPS in both dbc and dbw, and also throttle plate in dbw.
Old Sep 2, 2008 | 08:15 PM
  #18
auditech79's Avatar
Same difference, TPS sensor, module, whatever. I guess you can do an adaption to show the sensor the correct percentage values, but if there is carbon build up on the valve the adaption will be wrong regardless.
Old Sep 3, 2008 | 01:07 PM
  #19
Superdug's Avatar
So if the throttle is more then 3% at idle, there is a good chance of carbon build up on the sensor. if we clean that it should get us back to running good, could the sensor also just be going out?
Old Sep 3, 2008 | 01:44 PM
  #20
auditech79's Avatar
Carbon doesn't build up on the sensor, it builds up on the throttle valve. The carbon is holding the valve open more than it should be at idle. Then sensor just records how open the the valve is. 1% being all the way closed, 5% WOT (wide open throttle)
