Error Code P1559
Old Sep 3, 2008 | 02:02 PM
  #21
love the booB5's Avatar
SoCal Crew Member
Ok so is this something I can take care of with some fuel system cleaner? That seems like way too easy of a fix for this. Am I going to need to remove my throttle body and manually clean this valve?
I'm not sure carbon build up is really the problem here. If anything, it feels like the throttle valve isn't open enough. My car has dipped pretty low in RPMs a few times when I first start it up and it feels like it wants to die. Does that help to shed any light on this?
Old Sep 3, 2008 | 04:33 PM
  #22
auditech79's Avatar
You only need to take off the intake line and spray the living hell out of the valve with some brake cleaner and use a cloth to manually open the valve and clean all the gunk out of there. You would be amazed how much 1% of throttle angle misalignment will mess with the engine managment, trust me. Once you have it all cleaned do another throttle body alignment and it should run like the day you bought it.
Old Sep 3, 2008 | 04:45 PM
  #23
SoCal Crew Member
OK that sounds easy enough. Just to make sure I understand this though, all I need to do to realign my throttle body is to clear the error code with a VAG-COM and and leave my key in the on position or manually adjust it via VAG-COM? I'll play around with this sometime soon to see how it works out. Thanks for the tips. I'll be back soon with a report on how it went.
Old Sep 3, 2008 | 05:25 PM
  #24
auditech79's Avatar
Yep, just leave the key in the on position for about 10 minutes or set it with the vag com in the adaption channels, you just have to find the correct channel. I can't remember which adaption block it is.
Old Sep 3, 2008 | 05:44 PM
  #25
SoCal Crew Member
Sweet. Thanks again guys.
Old Sep 8, 2008 | 11:28 PM
  #26
SoCal Crew Member
Two things: cleaned the hell out of my throttle body and, while it didn't fix the problem, it did increase my throttle response a bit.
Just got my APR chipped ECU in the mail today. While installing it, my brother and I noticed that the ground for my coil packs wasn't screwed into the block. It was just resting on the head. So every time that lost contact, my engine wanted to die. Makes a whole lotta sense...
Easy fix, but I feel like an idiot. Whatever. My car is running very smoothly now and it's quite a bit faster. Today was a good day.
Old Sep 9, 2008 | 12:12 AM
  #27
auditech79's Avatar
Oh come one now! Thats all visual inspection.....Blah!!!
Old Sep 9, 2008 | 12:16 AM
  #28
SoCal Crew Member
I know, I know... it was a stupid issue that I should have caught immediately. Believe me, it wasn't a proud moment finding that I'd over looked something so minor.
Old Sep 9, 2008 | 12:24 AM
  #29
Jc61990's Avatar
if u keep your engine cover on then that may be reasonable, I used to never look under there, now my cover is always off
Old Sep 9, 2008 | 12:28 AM
  #30
SoCal Crew Member
My engine cover has been off for a few months now, actually. I really have no excuse here.
