Exhaust
Old Feb 13, 2012 | 08:37 AM
CCA4's Avatar
Downpipe != catalytic converter.
Your stock exhaust goes turbo ->cat ->downpipe ->rest of exhaust. People often replace the cat with what's known as a "test pipe" to increase exhaust gas flow and low end torque. That's what will cause you to fail emissions, because it replaces your cat with a ~2' piece of pipe. Some test pipes will trigger a CEL for a cat efficiency code, but this can be prevented by using a spacer for the secondary O2 sensor. If your state uses exhaust sniffers or does a visual inspection, this will also cause you to fail emissions, yes.
The downpipe is separate from everything I covered so far in this post. It bolts to the rear flange on the cat/test pipe and connects to the rest of the exhaust system with a large sleeve clamp. It's usually referred to separately from the test pipe and the rest of the exhaust because it can be removed by itself and many aftermarket exhausts don't come with a new one.
Old Feb 14, 2012 | 01:33 AM
sb301's Avatar
Thanks for the info cca4
Old Feb 14, 2012 | 10:49 AM
cincyTT's Avatar
I'm make believe
Be warned some high flow cats will also throw a code for no cat. With a spacer it can stop the code and you should pass both visual and sniffer tests.
Old Feb 14, 2012 | 02:28 PM
sb301's Avatar
Did you use a high flow cat? If you did, which one didI you use?
Old Feb 14, 2012 | 03:02 PM
cincyTT's Avatar
I'm make believe
I don't have emissions testing so I don't have a cat on the TT.I do know that the 42dd down pipe for the TT uses a small high flow cat and people get codes for the all the time.
Old Feb 16, 2012 | 12:40 AM
sb301's Avatar
Man I met a guy up today that was selling a magnaflow universal muffler ( part#14816), I did not expect it to be that huge! I ended up not buying it from him due to the tips being so big. I'm used to seeing nice fit ones on audi's maybe it would look nicer while on the car? The inlet is 2.5 and the outlet is 3.5. I'm assuming the outlet is the tips?
Old Feb 16, 2012 | 08:23 AM
cincyTT's Avatar
I'm make believe
Could be. The forum has posted the part numbers to mufflers used in the past.
Old Feb 16, 2012 | 08:54 AM
  #18
Infamisss1's Avatar
sorry to butt in,what does drone mean/
Old Feb 16, 2012 | 09:03 AM
  #19
CCA4's Avatar
Done refers to the resonance people sometimes hear from their exhaust when driving at part throttle and/or highway speeds. Most well planned exhaust setups (including straight pipes in some cases) sound pretty good at WOT because all you can hear is the engine, but there can be lots of loud resonance at part throttle, which makes them impractical for a daily driver. Its tough to find a good sound/video clip of resonance because the microphones on cheap cameras and cellphones have a hard time picking it up.
Old Feb 16, 2012 | 09:43 AM
  #20
cincyTT's Avatar
I'm make believe
Go follow a kid with a fart can for a few miles. You can hear their drone and just imagine how much worse it is for them. Basically a loud *** humming exh note at a steady speed
