Exhaust sound at idle and 2200rpms, sounds like one window down.
Old Jul 1, 2008 | 09:11 AM
ballon78's Avatar
Default Exhaust sound at idle and 2200rpms, sounds like one window down.
My 96 A4 q 2.8 has a weird sound at 2200 rpms and sounds just like if you roll just one window down in the back or just the sun roof and it makes a sound that hurts your ears. Even at idle it does it a bit, then if i rev it i can make it do it again around 2200 a little but while driving at 40 mph around 2200 its very anoiying and hurts the ears, if you lay into the gas it goes away...anyone have the same problem. If i push the cluch in at 40mph it goes away when the rpm drop down to idle.
thanks
Old Jul 1, 2008 | 11:07 AM
viper9821's Avatar
Default RE: Exhaust sound at idle and 2200rpms, sounds like one window down.
Maybe an exhaust leak? Get under the car and listen if you can.
Old Jul 1, 2008 | 02:30 PM
ballon78's Avatar
no leaks, it sounds like a drone sound, i have a twin engine boat and it does it when the two engines are are excectly the same rpm, and also if two streetbikes are riding next to eachother it will make the same type of sound...Its gets to you if your cruising back roads, i'd put an aftermarket exhaust on but i dont want it anymore loud.
02A4kid
Apr 10, 2014 04:49 AM
AuDiCaInE
Nov 13, 2013 10:27 PM
A4 2000
May 28, 2010 02:32 AM
theother1wstolen
Aug 21, 2009 07:26 AM
