failed drive clean test!! Need Help!
Old Oct 24, 2009 | 02:13 PM
audi_lade's Avatar
Default failed drive clean test!! Need Help!
Just failed ontario drive clean test, have a 98 1.8t with APR chip and intake 2.5 catback. They say i have a high CO% at idle the limit is .70 my a4 was at 2.68. Any ideas what it could be?
Government list says one of the following:
Maladjusted idle mixture
dirty air filter
faulty fuel injection system
faulty computerized engine management system and/or oxygen sensor
excessive electric fuel pump pressure
faulty air injection system
inoperative/missing catalytic converter
defective evaporative canister purge system
anyone have this problem before??
Thanks
Josh
Old Oct 24, 2009 | 08:05 PM
TeeterTawter's Avatar
how did you fail a 2step idle test? I have a highflow cat and no sai and i passed.
do you have a check engine light.
where in ontario are you located?
Old Oct 25, 2009 | 11:27 AM
CCA4's Avatar
lol you weren't even close!
hmmmm lets see...Are you the only one who's modded the car? Is it possible someone gutted your cat? (its a stretch i know, just thinkin out loud)
I would think that if your CO emissions are THAT high, your O2 sensors would be freaking out by now. Do you have access to an OBDII scanner or VAG-COM?
Old Oct 25, 2009 | 03:53 PM
^^^reason why i asked where abouts in ontario he is located, if hes anywhere near mississauga I can scan his car for him with my vagcom.
Old Oct 25, 2009 | 06:25 PM
exequiel3k's Avatar
Does anybody with a vagcom live in Quebec (montreal)?
Old Oct 27, 2009 | 08:41 AM
audi_lade's Avatar
I do have an odb2 scanner, I scanned it and no problems the co 2.86 reading was at idle. When I did the 2500rpm test it was at 1. The car was sitting for awhile so I dumped lucas injector cleaner and changed the filter. Im gonna drive it a couple times this week and do the test again this weekend. ANything else I should do?
Old Oct 27, 2009 | 08:44 AM
audi_lade's Avatar
Last test was two years ago and I passed, All I did since then was changed the diverter valve to the tt diverter and replaced all the vacuum lines. Can that have anything to do with it?
vgunjak
Jun 29, 2013 09:45 AM
vgunjak
Sep 23, 2009 08:21 AM
tatensty
Sep 9, 2008 07:01 PM
2kaudi
May 3, 2005 10:01 PM
