Finally diagnosed clunking/rattling in the front.
Old Jul 12, 2010 | 01:09 AM
A4 2000's Avatar
Default Finally diagnosed clunking/rattling in the front.
Today I did an oil change and while the wheel was in the air I remembered reading to shake it from side to side to see if something was loose. I ended up seeing that an end of one of the CA's was moving inside the knuckle. So I guess I just need to replace the CA? Why would it have play in there anyway?
Old Jul 12, 2010 | 05:25 AM
jiggleo's Avatar
It's a wearable part, why wouldn't it at some point?
Old Jul 12, 2010 | 10:41 AM
ImTheDevil's Avatar
When the CAs are in good shape they won't move. Time for replacement.
Old Jul 14, 2010 | 01:32 AM
A4 2000's Avatar
Ok, so actually the ball joint is tight in the knuckle, but loose inside the control arm. Someone told me that I could just have a shop press back in the ball joint with a machine. Is that even possible? I thought we had to buy the whole arm and ball joint together when something like this happens because it's all one piece?
I found this on youtube. This is exactly my problem. The same arm too.
http://www.youtube.com/watch?v=tbeBvu49ts4
Doc Rizk
Aug 5, 2012 09:22 PM
A4 2000
Nov 13, 2011 05:51 PM
jhsoccerodp
Nov 7, 2008 04:14 PM
Brandon2000s4
Oct 6, 2008 04:35 PM
jonah5
Aug 21, 2008 12:11 PM
