fluctuating rpm causing engine overheating and battery run down
Old Jun 1, 2011 | 07:38 AM
davike's Avatar
Question fluctuating rpm causing engine overheating and battery run down
when i start my car after stabilization the engine rpm fluctuates at a very high position, the temperature will rise and the battery will run down. pls what could be responsible for it. thanks
Old Jun 1, 2011 | 09:19 AM
Audisaurus's Avatar
if the bettery dies when the eingine is running, alternator
rpm fluctuation can be many things, vaccum leak would be a starts check under the egine cover there are these shitty cloth lines, they are more than likely fucked cracked
Old Jun 1, 2011 | 10:47 AM
davike's Avatar
How do I check for vacuum leak?
Old Jun 1, 2011 | 02:12 PM
Audisaurus's Avatar
look at the hose? itd very evident when there is a problem theres not just one theres a bunch of litttle ones that all mess it up at once. you will see if they are split and torn. i never checked any other way than that so idk
JDanielT
S5
Apr 29, 2015 12:26 AM
my barchetta
B7 Models
Jun 6, 2012 08:04 PM
Rainford
Sep 9, 2008 12:46 AM
