Fmic for stock ko3? (Eventually frankenturbo)
Anybody know how restrictive one like this is?-
Magnaflow 54305 Magnaflow Performance High-Flow Catalytic Converters
Because for $95 I would rather do that and just have my local shop weld pipes to both sides to make it fit
You used to be able to buy a 3" test pipe with OEM catalyst heat shields welded to it. Looked exactly like a cat but with nothing inside. I forget the name of the company now.
I would go that route personally. Way easier than trying to fit exhaust pipe inside the OEM cat. Don't know anything about Magnaflow cats but I do know that the word "universal" is usually a bad sign.
But even with heatshield a welded to it, if somebody tapped on the cat (like they do in va for inspection) it would sound empty... Also as far as the universal aspect, I think it is referring to the shape, you have to modify it to fit your car as it is just straight
This is why I run a test pipe 99% of the time and then swap my cat back in to pass inspection.
Most people don't want to do the extra wrenching, or will try to sell/recycle the catalyst to offset the cost of the testpipe. More worth it to keep both IMO. Once you get the hang of it, you can swap the cat in or out in about an hour. I have SAI and the secondary O2 readiness coded out in my tune, so I don't need to worry about codes, just passing visual.
http://www.ebay.com/itm/111048931028?redirect=mobileIf possible I would like to stay away from test pipe but if the hp increase is substatial I would definitely look into it
How much would a test pipe benefit me as oppose to a vehicle specific hfc like-
OBX Ceramic High Flow Cat 98 02 Audi A4 Base 4CYL 1 8L Passat GLS | eBay
Heh, for my last smog test, I had to swap out everything to pass! Turbo, exhaust manifold, FMIC, catch can, HFC, fuel pressure gauge/AFPR, removed wideband stuff from car, etc.
Alright I'll probably just do a test pipe. Metal man, having a frankenturbo and misc. stuff like that makes you fail it? We don't have emissions here in va (or atleast the korean guys i go to dont do it) but they do check to make sure you have a cat
By the way, I installed a ecs ra4 clutch because I thought mine was slipping. After 800 miles (should have broken in by now) it still had rapid slipping when I really get on it. I was told this could be caused by a clogged or just restrictive cat, is this true or is there something wrong with my clutch?
