Fmic for stock ko3? (Eventually frankenturbo)
Old Jun 17, 2013 | 01:09 PM
  #61
Pbcrazy's Avatar
I use 93 oct here, it looks like it's not going to make sense to run a ft for me since I have to have money in college so it looks like ill be sticking with a k03 . That being said I think I'm going to go with the first 2 links, I'm trying not to shave much off my bumper if at all. Thanks
Old Jun 17, 2013 | 02:03 PM
  #62
CCA4's Avatar
Honestly, this is probably what I'll end up doing as well, but with a larger core. I plan on going with a frankenturbo in the not-too-distant future but I'm not willing to hack up my bumper and lose my fog lights in the process.
Old Jun 17, 2013 | 02:09 PM
  #63
MetalMan's Avatar
You will still likely need to remove some material for stock bumper fitment, so expect that. But you shouldn't have to trim the aluminum bumper support to fit that FMIC.
Old Jun 17, 2013 | 02:21 PM
  #64
Pbcrazy's Avatar
I don't mind cutting some bumper but I don't want to have to be cutting almost all of it out. I wish I could do ft, but between rods, tune, injectors, etc. I'm looking at $2k which unless I get a full ride to college...isn't going to happen
Old Jun 17, 2013 | 04:18 PM
  #65
MetalMan's Avatar
With FT it isn't necessary to upgrade rods, at least for a B5 1.8T. (mine are original/stock @ 150k, FT since 135k)
Fuel pump could be required, depending on how yours is doing.
BUT: if you did go FT, I'd advise upgrading more than just engine/drivetrain. Just in general with cars, upgrading power should also be accompanied by an upgrade in brakes and suspension. Brakes would be most important, though, and are a good upgrade for the B5 A4. Many of us run the A8/TT setup with nicer brake pads, which works rather well, and is an excellent upgrade even if you're still running the K03.
Definitely put school first... your car will simply get you from place to place (whether K03 or FT), but a well-earned college degree will take your career forward.
Old Jun 17, 2013 | 04:49 PM
  #66
Pbcrazy's Avatar
I personally would upgrade the rods but I also have 193xxx miles on mine. If I do infancy get a full ride, $23k will go in my bank account (I have prepaid tuition but not room and board) in which case I may just have to make it a s4 big turbo rather then a4 . But the school I want to go to has not offered me anything at this time (other schools have). But I'll have to wait and see
Old Jun 22, 2013 | 02:00 PM
  #67
Pbcrazy's Avatar
Say I got the 6" tall one, the gap for my center grill is only about 3", wouldn't the only 3" of ic be blocked off airflow behind the bumper defeating the purpose?
Old Jun 22, 2013 | 05:07 PM
  #68
MetalMan's Avatar
If you applied the same logic to your radiator, then your engine wouldn't be cooled. It would be fine.
Old Jun 22, 2013 | 05:40 PM
  #69
Pbcrazy's Avatar
But the radiator is 2.5" behind the bumper so air can flow everywhere, whereas the fmic would be like 1/4" behind the bumper limiting air flow...but I guess air will probably find rs way
EliteTuning1
May 19, 2008 04:56 AM
dc878mmm
Sep 17, 2007 02:28 PM
crd945
Aug 5, 2007 09:22 PM
TeeterTawter
Jun 19, 2007 10:03 PM
mikejda
Dec 24, 2006 08:44 PM
