Fog Lights
Old Nov 7, 2010 | 11:30 AM
tware4021's Avatar
ooo thats the OEM fogs it looks like with the RS4 mesh! theres a guy on Audizine or Audiworld selling a sheet of the RS4 mesh so if you got the fogs you could buy the mesh and do it that way and thats just a a4 bumper
Old Nov 7, 2010 | 11:35 AM
czum09's Avatar
Yea I saw the mesh but its over priced and I think its plastic. Ive been looking but it's not easy to find unless im blind. I def want aluminum mesh.
Old Nov 7, 2010 | 11:39 AM
tware4021's Avatar
aluminum mesh = Rice
Old Nov 7, 2010 | 11:41 AM
czum09's Avatar
K ur right that is plastic rs4 and im def not riceing my car haha do u guys like that look?
Old Nov 7, 2010 | 11:49 AM
chocalotstarfish's Avatar
Super Moderator
i like the mesh look as long as its not aluminum!
Old Nov 7, 2010 | 11:56 AM
czum09's Avatar
Well im gonna go to the hardware store and see if they have anything... Im pretty sure a sheet of rs4 mesh is $80=ripoff
Old Nov 7, 2010 | 12:09 PM
ImTheDevil's Avatar
I think the RS4 mesh looks good if you match it with an RS4 grille. Yes I've done fogs many times before, aftermarket and OEM retrofit. What I'd tell you is to use a relay for powering them, and draw the relay's power not directly from the battery, but from one of the ignition-switched posts below the dash (one with a yellow wire). That way you can run them anytime using a switch you install but if you turn off the car the lights will shut off and you won't kill your battery.
Old Nov 7, 2010 | 12:26 PM
  #18
MetalMan's Avatar
That's EXACTLY how I have mine wired, except the signal to the relay comes from the ignition-switched post and the power comes from the battery. Not sure I'd try to power HIDs through the ignition switch. There is also an in-cabin switch that I installed between the ignition switch and relay.
Old Nov 7, 2010 | 01:03 PM
  #19
czum09's Avatar
Ok so does anyone have a link where I could get RS4 mesh?
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
