Fuel filter
Old Jun 5, 2012 | 08:43 PM
Sheasta's Avatar
Default Fuel filter
How often are they supposed to be changed my a4 has 134k on it (its a 1.8t). Is it hard to do? Ive done quite a bit of maintenance since i bought it (with misfires). Owner neglected it. Ive never used the seafoam should i give that a go as well?
Old Jun 5, 2012 | 09:21 PM
CCA4's Avatar
Its an easy job on a FWD. Not terrible on a Quattro, but its a bit tedious. Plenty of write ups out there about it if you wanna check it out
Old Jun 5, 2012 | 09:24 PM
Sheasta's Avatar
I got a quattro. I guess ill look it up. What about seafoam? Think i should just do it for the hell of it?
Old Jun 5, 2012 | 09:40 PM
ImTheDevil's Avatar
Seafoam is always good. Fuel filter I think is recommended at 30k but I'd go no longer than 60k (that's the interval for every other car I've owned). Do it - there's a DIY online that'll help. It will kill your fuel pump if you leave it alone (ask me how I know that).
Old Jun 5, 2012 | 09:50 PM
Sheasta's Avatar
How do you know ? Ughh I hope I dont FSU ive never done a fuel filter before. Or used seafoam for that matter. I can buy seafoam at like advance auto right?
Old Jun 5, 2012 | 10:02 PM
redmond1501's Avatar
Just did the fuel filter on my 2.8 quattro.
Hints
+ Use an OEM filter. My generic filter has a larger diameter at the top than the OEM filter, making replacement more tedious.
+ Retrofit the filter retaining strap bolt with a big ziptie.
+ When following the DIY (searchable) and you unbolt the fuel tank straps, try not to let the straps snap away from the tank -- they're a biatch to snap back in.
Having just fumes in the tank instead of half a tank-full will help with this.
+ Ideally, have a 20mm open wrench on hand.
+ Use ramps instead of jackstands.
+ I buy a lot of stuff online at Advance Auto with a 20% coupon code and then just pick it up at the store.
Old Jun 6, 2012 | 08:34 AM
CCA4's Avatar
I completely forgot about that, great advice. I did mine with a full tank of gas and I almost dropped a nut trying to lift the tank back up against the subframe when I was finished
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
DJmart
Aug 3, 2013 11:08 AM
ironman
Apr 16, 2007 03:53 PM
