fuel mileage
First of all, the "high mileage" on the first half a tank, and poor mileage on the last half a tank is your fuel guage sender unit. Most cars are non linear and this is common. Calculate your mileage over an entire tank, or use the mileage calculator on the console.
Bad mileage is caused by a number of things.
Mileage goes down in winter.
Mileage goes down if you use gas that is 10% ethanol
Mileage goes down if you haven't given your car a tune up (dirty air filter, spark plugs).
Mileage goes down if your injectors are dirty Try some techron or Redline injector cleaner.
Check for codes. Check the precat oxygen senor.
ORIGINAL: Got2Speed
well sine i got the car the light only came on ounce and had it cleared and hasnt came on since i believe it was a misfire.....and if you have the dealer do the oil filter how much will they charge $80 or is that just for the part?
