fuel mileage
Old Feb 24, 2008 | 12:59 PM
chaos92287's Avatar
Default RE: fuel mileage
it helps. its spreads the seafoam throughout the whole engine. you should jus do it 50 miles before your next oil change. and make sure the k&n filter you get is non-oiled
Old Feb 24, 2008 | 01:14 PM
Got2Speed's Avatar
do you oil it yourself or put it in your car non oiled?
Old Feb 24, 2008 | 01:19 PM
chaos92287's Avatar
get a non-oiled one and never oil it. the oil will ruin your MAF
Old Feb 24, 2008 | 01:28 PM
Got2Speed's Avatar
ok sounds good but does anyone know the price for an inspection at the dealership?
Old Feb 24, 2008 | 03:29 PM
Mrs C.'s Avatar
Thanks for all the help I'll see what the mechanic says
Old Feb 24, 2008 | 06:13 PM
david9999's Avatar
First of all, the "high mileage" on the first half a tank, and poor mileage on the last half a tank is your fuel guage sender unit. Most cars are non linear and this is common. Calculate your mileage over an entire tank, or use the mileage calculator on the console.
Bad mileage is caused by a number of things.
Mileage goes down in winter.
Mileage goes down if you use gas that is 10% ethanol
Mileage goes down if you haven't given your car a tune up (dirty air filter, spark plugs).
Mileage goes down if your injectors are dirty Try some techron or Redline injector cleaner.
Check for codes. Check the precat oxygen senor.
Old Feb 24, 2008 | 10:00 PM
d3m0nz3y3's Avatar
ORIGINAL: Got2Speed
well sine i got the car the light only came on ounce and had it cleared and hasnt came on since i believe it was a misfire.....and if you have the dealer do the oil filter how much will they charge $80 or is that just for the part?
its 80 bucks for everything. If you know anyone who has a vag-com, you can probably ask them to scan for codes. Its much easier to diagnose it that way. But if you dont, then do all the stuff chaos said. I have bad milage in my car, but it did improve alot after i got new fuel filter. However in my case, i know that i probably have a bad maf or o2. Just to lazy to get it fixed right now
Old Feb 24, 2008 | 10:14 PM
  #18
Got2Speed's Avatar
aiight thanks alot guys appreciate it
Mossyoakglock
Nov 14, 2010 12:50 PM
Redrum1
Aug 28, 2010 11:55 AM
audioi
Nov 18, 2007 09:17 PM
audioi
Jun 26, 2006 07:48 AM
audibility
Apr 7, 2005 08:14 PM
