Fuel pump upgrade 1.8T AEB
Old Mar 28, 2013 | 02:30 AM
redline380's Avatar
Legal Moderator
answered
Originally Posted by vtraudt
How easy is the Walbro intank GSS342 to install?
Originally Posted by redline380
best pratical pump upgrade for you is the walbro. i run the gss340 that i got from pagparts. it came with an install kit, but it was ****. the foam didnt fit the basket, didnt come with a sock. i wasnt happy with the kit. if you want the cleanest solution, i believe the only way to go is the atp aluminum adapter which fits in where the stock basket does. obvioudly more expensive, but better than the rings around my fuel pump im running. o yeah, since my pump didnt come with a sock, i ran down to oreillys and told them to find me one that fit. i jammed some chevy sock on my pump and im pretty sure its still on there. and just for a note, i cant hear hear my pump run at all
Old Mar 28, 2013 | 11:22 AM
Mike-2ptzero's Avatar
I actually ran a Walbro GSS340 in my stock basket with no sleeve and had no issues with it.
This company offers different thickness sleeves and sock filters that can be bought alone
This filter works for the GSS340
Old Dec 6, 2013 | 12:43 PM
vtraudt's Avatar
Originally Posted by Mike-2ptzero
The walbro fits in the A4 basket, it is smaller then the stock pump so using a sleeve will make it fit tighter.
What filter sock to use in conjunction with a Walbro 255 to make it a 'plug and play' install?
Old Dec 6, 2013 | 12:49 PM
vtraudt's Avatar
Originally Posted by MetalMan
I've "heard" the stock pump is good for up to 300awhp
Is there some substantiation for the 300 awhp (400 cHP in my books) available?
I have a fuel pressure gauge installed, and are not (yet) seeing a drop.
Running 22-24 psi on 350cc/4 bar, but pegging the 70mm (ID) MAF on my AEB from 5k rpm on. Area/flow corrected, that equates to 256 g/sec (320 cHP in my books).
Hope eliminate the current MAF bottleneck by installing a 76mm ID MAF housing (and corresponding fueling) this weekend.
If above claim holds water, I may still get by with the stock pump (not expecting to make more than 350 cHP even de-bottlenecked).
ECS Tuning
May 11, 2015 04:19 PM
Semperfiboost1
Jun 18, 2013 09:39 AM
carbonOX
Oct 30, 2009 05:47 PM
thareals4
Sep 2, 2008 08:07 PM
TTsteve
Oct 21, 2007 10:46 PM
