Fuel Trim: System too Lean?
Old Sep 26, 2008 | 11:24 AM
SlimChriz's Avatar
SOMEBODY STICKY THIS TOPIC!!!! lol just kidden
Old Sep 26, 2008 | 11:45 AM
Mike-2ptzero's Avatar
Originally Posted by auditech79
Just make sure you don't have any broken vacuum lines or check valves before replacing the O2 sensor.
Im going with a vacuum leak over an O2 sensor on this one.
Thats when looking at block 032 comes in handy. A vacuum leak after the turbo would show lean at idle and rich at part throttle, if the 02 sensor is going bad the fuel trim readings will show lean on both. Other things that will cause lean readings on both would be a maf going bad or a leak some where between the maf and turbo.
Old Sep 26, 2008 | 11:53 AM
waveblaster200's Avatar
Boosting to about 16-17psi steady, before fall off to 14-15 spikes around 18-20psi. I will be looking for cracked vac lines this weekend; does anyone have a good diagram of the vac lines near the intake or photos? I think the MAF the next inline to be replaced. Also I am running the Evom intake, does anyone know the filter diameter/cone size for replacement?
Thx for all the info!
Jon
Old Sep 26, 2008 | 01:12 PM
Ultim8gamr's Avatar
what do i need to do to look at block 032? I have VAG-COM but am still learning all its functions. should there be any reason for it to sound like a leak from the rear of the engine? near where the rear vac line from the manifold goes to some sort of valve it sounds like air or liquid flowing. This is only when the car is running, i have not been able to run a leak test with the engine off yet. i thought things were fixed then while coasting to a stop for a light, the car did a very slight stutter as if the AC had turned on and a lean code came up. I have an 01 1.8T with the same software version as the original poster of this thread.
Old Sep 26, 2008 | 03:04 PM
Just go into the engine section, then the measuring blocks. Just put in 032 where it ask what "group" you want to read.
ee99ee
Oct 28, 2011 04:34 PM
yuriy
May 3, 2010 04:04 PM
antonio
Dec 13, 2009 02:20 PM
daveck2
Sep 24, 2009 05:40 PM
vendingman2000
Feb 3, 2007 05:10 PM
