Halogen or HID?
Old Sep 3, 2009 | 09:07 PM
spector's Avatar
Default Halogen or HID?
So I recently bought my 2003 a4 (It's a b6, I know, but this board is much busier!) and I can't tell if it has halogens or HIDs. How can I tell?
Old Sep 3, 2009 | 09:23 PM
CCA4's Avatar
HID's have ballasts, halogens do not.
Old Sep 3, 2009 | 09:37 PM
Mr. Phil's Avatar
take a night pic and show us if u cant locate the ballast or dont know what they look like
Old Sep 3, 2009 | 09:43 PM
ImTheDevil's Avatar
When you turn them off, do they fade out or turn out instantly? When you turn them on, do they flash and then warm up to full intensity over 4-5 seconds? HIDs have the warmup time andvshut off in the blink of an eye.
Old Sep 3, 2009 | 10:03 PM
ghost6303's Avatar
HIDs also have a very clear side cutoffs, you will see clear edges to the light. halogens have a bright spot in the center that gradually fades to nothing as you move out to the edges.
Old Sep 3, 2009 | 10:16 PM
kriptonik's Avatar
Like ImTheDevil said, the easiest way to tell would be to watch the lights as you turn them on. Xenons usually take sometime to warm up and color will change from blue-ish/purple to pure white (as stock Xenons are 4300K; closest to daytime).
Old Sep 3, 2009 | 11:41 PM
spector's Avatar
Hm, I can't notice any color change when I turn them on. They do like somewhat whiter than normal car lights, though. I can check for ballasts tomorrow when there's more light. Here are the night pics, if it helps:
One is without flash, one is with.
Old Sep 3, 2009 | 11:55 PM
kriptonik's Avatar
How about check out the headlight housing. If you have Xenon, there should be a warning sign with a huge exclamation point (should be yellow). This should be on the cover of the back part (you need to pop your hood).
Also you could just pop open the cover and see what kind of bulb you have.
^That's a halogen H7 bulb
Old Sep 4, 2009 | 12:06 AM
spector's Avatar
Ok, I'm pretty sure I've got halogens. I found a blue sticker (no yellow warning label) on the far side of my housing (hidden by the frame) that says Valeo and has "h7" written in several places.
H7s it is. Any good DIY for the Xenons? Is it worth getting them?
Old Sep 4, 2009 | 01:21 AM
kriptonik's Avatar
I've got factory Xenons so it came with the whole setup and the housing (D2S).
If you want to go that route and replace the whole housings with OEM Xenon, it will probably cost you some penny unless you can source some used parts.
However, you can just buy an aftermarket HID kit. Most pople go this route since it's cheaper. I believe it's pretty much plug and play but you might have to drill a little hole on the cover for the cable/plug to go through.
Many here have purchased kits from VVME but recently I've been hearing good things about DDM - which is a local company unlike VVME that's based oversea (China I believe).
http://www.ddmtuning.com/
Best of luck.
