Halogen or HID?
Old Sep 7, 2009 | 01:17 PM
  #21
spector's Avatar
It should work with those headlights. It is recommended to use projector headlights with HID's due to the cut-off point so you won't blind the on-coming traffic.
If you do get the slim kit with tiny ballast and you're able to fit it inside the housings, then drilling will not be necessary. Drilling is usually required when you put your ballast outside the housings in which you will have to run the cable through (which might required drilling).
How do I know if I have projector headlights? I see things about leveling and self-leveling, but I can't find any good info about what needs to be done with the stock halogens and the aftermarket HID kits.
Will I have any levelling problems using the DDM kit with the stock halogens?
ECS also has blackout headlight kits for OEM HID headlights... maybe those would be a better choice for an HID conversion? Or perhaps someone here can recommend a good blackout HID kit combo?
dlancey
Jul 20, 2011 10:21 AM
dbseventy00
B7 Models
Sep 20, 2010 12:46 PM
2FAST4U
Jan 2, 2008 01:14 AM
Dallas09
Dec 25, 2007 01:33 AM
meangreena4
Apr 24, 2007 09:54 PM
