Hard Knock from Undercarrage
Old 02-21-2012, 05:55 PM
Parkerboy's Avatar
Default Hard Knock from Undercarrage
I believe my differential is causing a knocking sound. Has anyone had an issue like this before? is this a costly fix?
Old 02-21-2012, 05:58 PM
M5S5's Avatar
Tech Certified
Front or rear of vehicle can it be heard?
Over bumps ?
When accelerating or decelerating?
Think we need more info to go on for help to be offered.
Old 02-22-2012, 04:19 PM
Parkerboy's Avatar
the knock is coming from the rear. it happens during acceleration after a gear change, sometimes if i accelerate quickly it will give me a slight knock as well
Old 02-22-2012, 04:51 PM
bmoore98A4's Avatar
check your diff fluid and for shaft play. In my old tahoe after towing our boat the rear leaf springs streched and would produce a knocking/metal on metal sound. Granted that a tahoe is not an audi haha
Old 02-22-2012, 05:01 PM
M5S5's Avatar
Tech Certified
I would check you center support bearing on the driveshaft. It will clunk on acceleration & shifting.
Old 02-22-2012, 05:22 PM
Dozanti's Avatar
Don't forget to look for cracks in the subframe, missing bolts, or broken subframe mounts !
BMW e36 body styles are well known for this, seen it a few times on audi's as well
Old 02-22-2012, 05:53 PM
bmoore98A4's Avatar
My center support bearing is on its way out
These quattro systems are basically LSD correct?
Old 02-23-2012, 08:15 AM
chocalotstarfish's Avatar
Super Moderator
Rear diff mount. Replaced mine last year. If when you shift and stomp on it it sounds like the hooker in the trunk is kicking the floor boards that's it.
Got mine from Ringer-Racing.com super easy fix about 35 mins.
Old 03-02-2012, 03:57 PM
Parkerboy's Avatar
Thanks for the help guys
PoloBLK
05-29-2011 12:46 PM
vlado182000
07-16-2010 03:20 AM
B5Bobby
08-08-2008 01:50 AM
greene08
12-13-2007 03:26 PM
diehlryan
05-27-2007 12:52 PM
Quick Reply: Hard Knock from Undercarrage
