knock still there
Old Jul 13, 2010 | 07:11 PM
vlado182000's Avatar
Default knock still there
hello everyone i had a knocking sound coming from the front side. i took it to the dealer and they told me my lower control arms and sway links were bad so i bought complete control arm kit and the wheel bearings and replaced it but the problem is still there. every time i turn left then right it makes the noise. in the morning its not so bad but when it gets hot then it does it more often. I lifted the front end up and had someone move the steering wheel left and right while I was listening to it, and it seems like the noise is coming from inner tie rod.I searched the forum and found a lot of people say the cv joint needs to be replaced.
any ideas?
Old Jul 13, 2010 | 11:46 PM
anyone????????????
Old Jul 14, 2010 | 12:16 AM
Tourbo24's Avatar
did you check your power steering fluid level? i am not sure if it would make a knocking sound if you were low on it but it would make a weird noise when turning the steering wheel.
Old Jul 14, 2010 | 06:28 PM
i checked the power steering its at max
Old Jul 15, 2010 | 10:08 PM
today it started to squeak when i turn left anyone had this problem...
Old Jul 16, 2010 | 03:20 AM
drs2000rr's Avatar
check the bolts holding your power steering rack and the outer tie rod joints...
pbbg
Dec 2, 2013 10:05 AM
PoloBLK
May 29, 2011 12:46 PM
B5Bobby
Aug 8, 2008 01:50 AM
90sMoneypit
Jan 14, 2008 07:21 PM
diehlryan
May 27, 2007 12:52 PM
