Has anyone EVER timed a 1.8 cam chain?
Old Mar 20, 2008 | 09:38 PM
auditech79's Avatar
Default RE: Cam chain, am I doing this right? ("98 A4 1.8)
If you are sure you have 16 links between these marks and the timing belt is lined up, its possible the cam tensioner is sticking which will cause missfires accross all cylinders. There is a data block to check it with the vag com, can't remember which one though. I know for a fact its between blocks60-80, it should be open or closed, on or off. If its stuck in just one of these positions your SOL. You need a new tensioner.
Old Mar 20, 2008 | 10:25 PM
wkayl's Avatar
Thanks for all the help guys. As it turned out I did have it 1 link off. I took it apart and installed it correctly. I did have a scarry monent though. It didn't have any compression after I had it all back together (engine just spun freely). I did a compression test and had compression on #3 only. After a rant (I don't throw tools just use colorful language) I tested them again. This time #1 also had compression. I put the plugs in and it started up. Ran rough for about 10 min and then ran smoothly. I think we got it. The cam chain clicks some so I just ordered a new new one just to be safe. Happy days are here again. Time to have a Bud Light and color Easter eggs.
Old Mar 20, 2008 | 11:22 PM
auditech79's Avatar
Good job, those are pretty hard to get right. I had to practice those a lot at the academy, it always busted my *****.
Old Mar 31, 2008 | 11:09 PM
wkayl's Avatar
It's alive, it's alive!!!!! I just took it for a test drive and it runs great. It took a couple of weeks longer than expected asI ordered a cam chain tensioner and installed it. When finishig things upI discovered the fan blade broken. I think it got stepped on in all the activities.
Old Apr 1, 2008 | 09:46 AM
Jeff's Avatar
Zombie Defense Force
nice glad its all ok now
Old Feb 9, 2009 | 03:13 PM
jzmuda's Avatar
Default you are off by a tooth
I just did this this weekend both nothes have o line up with the arrow on the cam caps and the 16 links is correct however the left one starts one tooth tothe left of the mark on the exhaust side on the sprocket, hope that helps.
Marcski
Mar 22, 2010 11:51 AM
Mlaubach
Aug 20, 2008 01:38 PM
keko2004
Oct 12, 2006 11:21 PM
95spiderman
Nov 27, 2005 03:23 AM
Dudek12
Sep 3, 2005 06:03 PM
