Head gasket replacement/cam gear removal. Help Anyone????
Old Jun 19, 2012 | 06:53 PM
rough pearl's Avatar
Red face Head gasket replacement/cam gear removal. Help Anyone????
Does anybody know how to remove the cam gears off of a 2.8? is it pretty simple or...? I am going to try to remove the heads for a head gasket replacement. Is there a link to this that anybody knows of? Can anybody help?
Old Jun 19, 2012 | 08:55 PM
mtroxel's Avatar
Sure. You just loosen that 17mm (?) bolt that holds them on...loosen. Leave it on so you don't have to worry about the sprocket hitting the ground. The put the teeth of a 3 prong gear puller behind the sprocket and crank down on the bolt that lines up with the end of the crankshaft. You'll hear a pop...and the sprocket is free.
Looks like this:
schiek
Nov 30, 2008 04:04 PM
BMoneyCartel
Jan 19, 2008 02:18 PM
hubturn
Mar 5, 2007 09:21 PM
Jex
Oct 28, 2006 11:08 AM
audi82
Jan 18, 2006 07:29 PM
