headlight problem...
Old Mar 31, 2008 | 09:51 PM
CL AUDI EOUS's Avatar
Default headlight problem...
My headlights aren't working and from what I have read it sounds like I will need a new switch... So my question is does anyone in the Mesa, AZ area know a good shop that could install this for me? Could also be in Tempe, Chandler, Scottsdale, etc...
Old Mar 31, 2008 | 10:15 PM
ejgold55's Avatar
Default RE: headlight problem...
im new here too, but this just happened to me and it was the ignition switch...BUT i had no wipers, a/c blower, temp display, rear defrost, AND brights still worked when i pulled the stalk back. the back of the ignition switch was burnt up. there is a good writeup at audidiy.com - click on b5 platform - i'm assuming you have a b5
Old Apr 1, 2008 | 04:06 AM
Yea i have checked the wipers, i KNOW my a/c works cause i live in AZ and all the other stuff works... brights are the same way on mine... i am not the greatest with DIY work though...
Old Apr 1, 2008 | 07:38 AM
hiwords's Avatar
here ya go http://www.audiworld.com/tech/elec.html
Old Apr 1, 2008 | 09:52 AM
flyromeo3's Avatar
its very simple. If you know how to unscrew something then this will be a piece of cake. Just make sure when everything gets placed back on that your steering wheel is set correctly.
One step I did was to lock the steering wheel and then make certain that the black box thing that locks it in place is installed the same way ( you'll see what I mean when you remove the wheel )
Old Apr 1, 2008 | 10:15 PM
alright so this might sound like a stupid question, but i am curious... I have taken of my steering wheel and column and was wondering if i had to put everything back together to test and see if my journey to the light switch worked or if i can just plug my battery back in and check...???
a. debarros
Jun 24, 2011 11:57 PM
bpguitarbiker
Aug 20, 2008 11:20 PM
paparose_12
Oct 29, 2007 10:00 PM
DieHardAudiA4
Oct 13, 2007 11:14 PM
The Somps
Feb 18, 2007 08:10 PM
