Headlight Washers
Old Dec 2, 2012 | 10:25 PM
Luc's Avatar
Luc
Default Headlight Washers
Just replaced my headlight washer pump but still not getting the headlight washers to pop up or spray. I also checked the fuses and they seem to be in working order, in fact I can hear the headlight washer system tick when I pull on the washer lever, but still nothing. Any ideas on what could be the problem?
Old Dec 3, 2012 | 08:02 AM
CCA4's Avatar
To get the washers to come on, the headlights need to be on and you have to hold the stock for something like 3 seconds. Do you see any leaks? The sprayers popping up is caused by the liquid pressure from the washer fluid, so if the pump is working and there are no leaks you should be good.
Old Dec 4, 2012 | 05:34 PM
Luc's Avatar
Luc
I've done all the basic things to ensure it works on my end but I feel it may be a deeper issue then the easy fixes. One of two things I'm guessing; The actual sprayers are junk/blocked or I'm not getting any power to the pump. I just picked up a meter to test if there is any power and will try this weekend. On the other hand its more of a luxury so if I can't figure it out on the cheap, I'm fine without them.
Old Dec 4, 2012 | 06:25 PM
jonbonesjones's Avatar
Moderator
hold it for like 20 seconds and see if they pop up. with the lights on. If not, then like you said, luxury. I had the holes covered on mine, its a way better look.
Old Dec 5, 2012 | 08:56 PM
Luc's Avatar
Luc
I bought new headlights and to keep the lenses clear from salt this winter, I'm willing to try out a few more things and then I'm giving up. So tomorrow I will be pouring in another gallon of wiper fluid and crossing my fingers.
WGA
Audi Q7
Jul 28, 2008 10:14 PM
Lopster99
Mar 6, 2007 08:03 PM
dlinbh
Oct 16, 2005 04:13 AM
///A4
Sep 7, 2005 07:50 AM
