headlights,wipers,fog switch,climate control, turn signals not working
Old Apr 28, 2011 | 01:34 PM
McQ-b5a4's Avatar
Exclamation headlights,wipers,fog switch,climate control, turn signals not working
My headlights,fog switch,climate control, turn signals not working. Also, the temp in the instrument cluster isn't displaying either.
However the parking lights, brake lights, hazards and radio all work and the car runs fine. 1999 a4 2.8
I know it could be the load reduction relay so I ordered one. If it isn't not that, can you guys offer any suggestions as to what else it could be?
Any help would be appreciated.
Old Apr 28, 2011 | 01:40 PM
rcheing's Avatar
I'm assuming you have already checked each fuse in the fuse panel on the driver's side?
Old Apr 28, 2011 | 01:44 PM
McQ-b5a4's Avatar
Yes, first thing. They are all fine.
Old Apr 28, 2011 | 02:06 PM
morpheous's Avatar
Could be the light switch stalk,they are known to go bad,there is a DIY repair article somewhere on the forum,just run a search,good luck friend
Old Apr 28, 2011 | 03:39 PM
McQ-b5a4's Avatar
I took off the steering wheel and cleaned/checked the headlight switch and its connects. It is ok.
Old Apr 28, 2011 | 05:12 PM
Dallas09's Avatar
Im thinking ignition switch, described perfectly here: http://www.audizine.com/forum/showth...=1#post6244465
Old Apr 28, 2011 | 06:05 PM
McQ-b5a4's Avatar
Thank you for that link. The ignition should be here tomorrow, so i'll post back if that is actually the issue.
Old Apr 29, 2011 | 02:18 PM
spcmky's Avatar
I had the same issue. I changed out the ignition switch and it ended up being the load reduction. I carry a few in my car just in-case it happens again.
Old Apr 30, 2011 | 11:32 AM
McQ-b5a4's Avatar
so, after picking up an ignition switch and taking apart the steering column again, it was the switch. I also sandpapered the headlight switch contacts since they were looking very worn.
here is a pic of the orginal ignition switch. I circled in red the contact that had shorted.
Uploaded with ImageShack.us
Old Apr 30, 2011 | 11:39 AM
patrixx006's Avatar
if you ride around with your stock fog lights on that will cause the ignition switch to go out all the time.
MARKANTO13
Jun 25, 2021 04:27 AM
ledzepp2994
Aug 12, 2010 08:13 PM
hedman09
May 18, 2009 02:34 PM
MARKANTO13
Mar 1, 2009 06:14 PM
