heated seats not working
Old Dec 17, 2013 | 09:21 PM
Mhuntington's Avatar
Default heated seats not working
anyone know if there is a way to replace the heating unit in the seats? or would i be better off just replacing the seats themselves?
Old Dec 17, 2013 | 11:30 PM
HBAudi's Avatar
Is the electrical circuit functioning correctly?
Removing and replacing the seat assembly is simple, but there may be another reason your heating elements are not working that may save you time and money.
Unless the heating element is physically broken, the problem lies elsewhere in the circuit. Check the plugs under the seats to see if they are securely connected, check the earth (grounds??) connections for corrosion or loose fit and if possible, remove the seat and check the element with an ohm meter for an open or shorted element.
vtraudt
Oct 8, 2012 05:39 PM
crayzdavy
Nov 5, 2007 04:23 PM
mustang196718
Oct 21, 2007 01:27 AM
Buttery Cracker
Oct 1, 2007 01:48 AM
