heating problem
Old Jan 19, 2009 | 06:10 PM
re3188's Avatar
Default heating problem
i have a 98 a4 2.8 and the heat is not working right. when i drive the heat will work but when its at idle it blows out cold air it just started doing that today. does anyone know whats wrong?
Old Jan 19, 2009 | 07:17 PM
a4nick's Avatar
Kinda sounds like a bad water pump. Do you have any coolant leaking?
Old Jan 19, 2009 | 08:07 PM
SAudi's Avatar
i agree, happened to my a4 when i replaced the t-stat but lost the o-raing and also to my buddys vr6 when his water pump went.
Old Jan 19, 2009 | 08:23 PM
Tweaked's Avatar
Does the temp gauge work?
If so, top the coolant and drive the car until warm. At idle, pull the return line to the coolant overflow tank. If you have flow, the water pump is working. If there is no flow, suspect a bad water pump or T-stat. Another possibility is the heater core. If it's leaking, you'll likely smell coolant in the cabin or have a wet passenger floor.
Old Jan 19, 2009 | 08:44 PM
re3188's Avatar
flow meaning it it will over flow?
Old Jan 19, 2009 | 08:45 PM
Tweaked's Avatar
No... pull the small line going to the top of the tank. If it pees all over, you've got water flow.
Old Jan 21, 2009 | 06:18 PM
re3188's Avatar
when i didi that it fluid shot out then stoped and now i also have problem with the steering when the car is cold its loose but when it warms up its stiff but when i start driving it go backs to normal then when i stop at a stop sign its stiff again any ideas?
DaveQ7
Audi Q7
Sep 16, 2014 01:58 PM
Julianpnc
Oct 23, 2012 04:15 PM
Paul Rasmussen
Oct 10, 2012 08:51 PM
plumbous
Dec 15, 2009 10:19 AM
jj2345
Aug 21, 2009 11:06 PM
