help
Old Mar 11, 2008 | 12:26 PM
  #21
less_of_me's Avatar
Default RE: help
ORIGINAL: McGovs1.8B5
Is the sound only at idle? Mine made sounds similar to what you described and it ended up being the cam chain tensioner. No one mentioned it yet thought I'd toss it out there.
Did you fix this yourself? Is there a DIY for this job? I searched, but could not find one..
Old Mar 11, 2008 | 01:09 PM
  #22
McGovs2.7TB5's Avatar
Default RE: help
I didn't fix myself i can do basic stuff but whenyou start tearin the whole front end off, thats over my head. Look here for a diy www.audidiy.comWasnt a cheap fix, the part is pricey.
Old Mar 11, 2008 | 11:02 PM
  #23
kloepfer_3's Avatar
Default RE: help
ill tell u wat light come on. when u look at your oil temp on your gauge thing. the little display of the oil right by the temp thats the oil symbol light i get. but i added oil and stuff and it comes on
Old Mar 12, 2008 | 09:26 AM
  #24
Default RE: help
Was the light red or orange? Red=low oil pressure (not good) Orange=low oil level (also not good but not as bad as red).
If it was red search 'seafoam' and do an oil change after that treatment.
Old Mar 12, 2008 | 10:55 AM
  #25
kloepfer_3's Avatar
Default RE: help
lets say its red i dont know. why is that worst then the other one???? what does that mean causing it to be so bad??
Old Mar 12, 2008 | 01:45 PM
  #26
Default RE: help
The low oil pressure indicator can be a sign of engine sludge. The sludge gets caught up in the oil pick up tube thus clogging it and causing low oil pressure. I guess the orange one can just as bad if you've got an oil leak somewhere.A seafoam treatment may help clean some of that sh** out of there. GL.
Old Mar 12, 2008 | 11:32 PM
  #27
kloepfer_3's Avatar
Default RE: help
if it is sludge, what is the best way to get rid of it???
Old Mar 13, 2008 | 12:17 AM
  #28
ImTheDevil's Avatar
Default RE: help
Seafoam treatment is a good start. Search here - there's a million posts about it, and an active thread somewhere in the first few pages of this forum.
Old Mar 13, 2008 | 12:20 AM
  #29
a4audia4's Avatar
Default RE: help
Probably because low oil pressure means you're leaking somewhere... whereas low oil you can just fill.
Old Mar 13, 2008 | 12:45 AM
  #30
duburban's Avatar
Default RE: help
Is it possible that the leak i have could be causing my lifters to tick or tap from low oil pressure?
