HELP! Brake pedal goes to floor after flush and bleed...
Old Feb 23, 2012 | 06:47 PM
bshusted's Avatar
Exclamation HELP! Brake pedal goes to floor after flush and bleed...
I spent the afternoon flushing my brakes. I used a pressure bleeder similar to the Motive one. I flushed through a liter of new dot 4. Started at the RR, LR. Then RF and lastly LF. The pedal feels very firm if the car is off, but as soon as I start it, the pedal goes straight to the floor.
The fluid level in the master cylinder never went below the min mark.
What gives? The brakes worked before, but the fluid was nearly black, so I thought I would be nice to my car and change it.
Can you guys think of anything I've missed? I can't run the ABS pump without the obd software, right?
Old Feb 23, 2012 | 08:54 PM
MetalMan's Avatar
Manual transmission? If yes it is my understanding you should also bleed the clutch slave cylinder.
Old Feb 23, 2012 | 09:22 PM
bshusted's Avatar
Problem Solved! I was skeptical, but I read somewhere that these cars are bled in reverse order. Start at LF, RF, LR, and then RR. I tried it and it made all of the difference. The only thing I can figure is that it pushes the fluid through the ABS pump differently.
The clutch should be bled at the same time since it shares the same reservoir.
Old Feb 24, 2012 | 05:46 AM
bradtyler02's Avatar
Aha! Guess it wasn't **** in your pic in the other thread...!
Mkacz373
Feb 15, 2014 09:54 PM
mcmopar
Jun 20, 2013 08:49 PM
fabianandres
Mar 8, 2010 02:25 PM
ouijacom
Aug 6, 2009 11:21 AM
Trey25
Jan 27, 2008 03:27 PM
