HELP!! Cant see anything with my projectors
I have a a4 with projectors but i cant seem to see anything when im driving my fogs are the only things that light up the road and when i turn on my highbeams they are aiming at second floor buildings, how do i adjust them??
The adjustments are 6mm allen screws behind the lights under the hood. There is one accessible through the fender that does aiming left and right and another about midway between the fender and the radiator that does the up and down.
To aim them properly, find a level parking lot with a wall at one end. Pull up to the wall as close as you can and mark the position of the step and cutoff with painter's tape. Back away from the wall ~25ft adjust the screws until the cutoff is 3" below the line you marked and the steps are in the same location.
