HELP!! Cant see anything with my projectors
Old Jan 15, 2013 | 03:27 PM
GusTaVz_a4's Avatar
Default HELP!! Cant see anything with my projectors
I have a a4 with projectors but i cant seem to see anything when im driving my fogs are the only things that light up the road and when i turn on my highbeams they are aiming at second floor buildings, how do i adjust them??
Old Jan 15, 2013 | 03:40 PM
01 Avant's Avatar
did you do any type of work recently that would have caused the lamps to be removed?
Old Jan 15, 2013 | 04:20 PM
bshusted's Avatar
The adjustments are 6mm allen screws behind the lights under the hood. There is one accessible through the fender that does aiming left and right and another about midway between the fender and the radiator that does the up and down.
To aim them properly, find a level parking lot with a wall at one end. Pull up to the wall as close as you can and mark the position of the step and cutoff with painter's tape. Back away from the wall ~25ft adjust the screws until the cutoff is 3" below the line you marked and the steps are in the same location.
Old Jan 15, 2013 | 05:34 PM
GusTaVz_a4's Avatar
ok so the one in the fender does left and right and the one closest to the radiator does up and down so is it clockwise down and counter clockwise up?
Old Jan 15, 2013 | 05:57 PM
george1546's Avatar
It doesn't matter, you'll be their adjusting your lights, no point in asking which way you spin it, try counter clock, if they don't go down, go clockwise then. Simple.
Old Jan 15, 2013 | 06:28 PM
Slowb5's Avatar
this.
AudiTurbo
Oct 15, 2009 03:00 PM
sbristow84
Sep 8, 2009 09:21 PM
vegastt
Feb 7, 2009 04:42 AM
cg8798
Nov 28, 2007 01:09 AM
jtjohnny102
Mar 7, 2005 01:05 AM
