help, check engine light on after bov installed.
Old Oct 31, 2009 | 04:40 PM
yoga129's Avatar
Originally Posted by ghost6303
you can use a BOV without problems if its adjusted correctly and closed at idle. most people have a hard time figuring out how to do this, which is why a DV is a better choice. there is no performance gain using a BOV vs a DV on the stock turbo. unless you have a real reason to use one, stick with a DV so i dont have to keep reading these threads.
i dont really care about performance, i dont race anyway. its just sounds cool. its enough reason for me. do you know how to adjust bov?
Old Oct 31, 2009 | 07:02 PM
TeeterTawter's Avatar
I have the exact same valve as you, the forge splitter, you can only make it full dv, full bov, and hybrid 50 50.
you can adjust how stiff the valve spring is by turning the top, here for more details http://www.forgemotorsport.com/conte...duct=FMDVSPLTR
Old Oct 31, 2009 | 08:20 PM
2fast4u66's Avatar
has anyone tried our maf inline, after the bov/dv?
Old Oct 31, 2009 | 11:09 PM
ghost6303's Avatar
Originally Posted by dragonrage
No... because your MAF measures the air the car is taking in and it does not account for what the BOV is blowing off.
it takes about 100-500 milliseconds to shift for the normal person. running rich for that small amount of time is inconsequential. quite a few people use BOVs without problems. as long as it is closed at idle and only opens when you shift, its fine.
like putting the MAF after the turbo? that would not work because the MAF reads air speed not volume. the ECU computes the volume by measuring the air speed, plus the known size of the MAF opening plus the atmospheric pressure. if you put the MAF after the turbo that would change the atmospheric pressure and the ECU would not know whats going on.
Old Oct 31, 2009 | 11:49 PM
bradtyler02's Avatar
I think the lesson here for all (and we'll all have to say it all again very soon) is that having a BOV just for the "cool sound" is pretty ricey. Honestly, if it is such a hassle, possibly damaging, and the car was designed with a DV, just stick with a damn DV!
Old Nov 1, 2009 | 01:19 AM
dragonrage's Avatar
Another problem with putting the MAF after the turbo is that the oil that gets by the turbo will coat the MAF and make it need frequent cleanings.
Old Nov 2, 2009 | 04:36 AM
yoga129's Avatar
I don't mean to be rude but, why you talk about dv, bov sound and bla bla bla. I am trying to get an alternative to make bov works fine not to argue dv is best or the damage to a car.
Old Nov 2, 2009 | 06:43 AM
  #18
Originally Posted by yoga129
i have audi a4 b5 1998 1.8t automatic. i change the stock dv to the forge splitter and i set 100%bov. for the first week it runs good and no problem. but on traffic stop and go, sometime my rpm drop very low and causing engine stall. the check engine light also showing. is there anyway to fix this?
I don't mean to be rude, but you asked how to fix it... If you don't like the answers, don't ask the question...
parlayin
Feb 10, 2010 12:33 PM
musiclman
Mar 25, 2008 08:43 PM
MrTigz5254
Mar 7, 2008 11:56 PM
blanthony
Mar 25, 2006 01:18 PM
