2.8 quattro clutch problems
Old Nov 1, 2009 | 08:08 AM
stquattro's Avatar
Default 2.8 quattro clutch problems
I have a 1999 A4 2.8Q manual, recently there seems to be too much play in the clutch pedal when starting from cold but when the car warms up the pedal becomes firm again. what could this be?
Thanks
Old Nov 1, 2009 | 11:16 AM
codymack43's Avatar
did you check the hydraulic fluid? My clutch was soft until I filled up the hydraulic fluid, then it was fine again
Old Nov 1, 2009 | 11:27 AM
pullacowonaski's Avatar
were is the fill up point at
Old Nov 1, 2009 | 11:59 AM
ghost6303's Avatar
the brake fluid resevoir is also the clutch fluid resevoir. when is the last time you did a brake fluid flush?
Old Nov 2, 2009 | 06:14 AM
stquattro's Avatar
The fluid level is ok, i remember changing it 15000 miles ago.
Old Nov 2, 2009 | 08:38 AM
ghost6303's Avatar
did you also bleed the clutch after you bled the brakes?
audia41997
Feb 11, 2014 05:38 PM
dusted72
Sep 19, 2010 09:32 AM
Santorin2k2
Jun 5, 2006 06:27 PM
SamJamaica
Jun 13, 2005 02:07 AM
