Help with check engine light I have codes.
Old Dec 31, 2008 | 05:39 PM
  #21
Dallas09's Avatar
Throttle body adaptation, it can fix rough idles and wanting to die. If you leave the key on you can hear a hum, thats the throttle body, leave it on for 2 or 3 min.
Old Jan 2, 2009 | 10:18 AM
  #22
activeautosports's Avatar
Hmm I tried the TBA with no results. So what are the normal readings from the MAF sensor when its plugged into the scanner? I cant exactly remember what it was saying but i believe that it was around 30 at idle and reved up a little bit it was at 80.
Old Jan 2, 2009 | 06:05 PM
  #23
Dallas09's Avatar
Im pretty sure it should be somewhere around 3 or 4 at idle I believe, id try replacing the MAF then. How does it run when you unplug it?
Old Jan 3, 2009 | 05:11 AM
  #24
It runs exactly the same when I unplug it.
Old Jan 3, 2009 | 01:08 PM
  #25
Chicagoaudi98's Avatar
Member
Just a thought and I know this was mentioned earlier, were the sensors cleaned up?
Old Jan 4, 2009 | 12:01 PM
  #26
I haven't had a chance to do the temp sensor yet but I cleaned the MAF with the MAF cleaner three times. I have been trying to figure out the brakes recently... https://www.audiforums.com/forum/sho...d.php?t=121797
Old Jan 11, 2009 | 11:14 PM
  #27
So with the vag com what should be the proper reading from the Mass Air Flow Sensor in g/s? At idle I was at about 4.09 g/s. is there a reading that would be normal for idle and at a given upper RPM?
RedA4guy
Mar 15, 2014 08:59 PM
rb12
Apr 27, 2010 01:14 AM
TimmyTT
May 18, 2008 10:08 PM
Mattchef
Sep 7, 2007 06:10 PM
