HELP, engine failure, gas pedal not working, engine vibration.
Old May 5, 2010 | 10:47 PM
10kRedline's Avatar
Default HELP, engine failure, gas pedal not working, engine vibration.
Ok, I have a b5 a4 1.8TQM. Today was hot like hell, so I turned on the A/C, as soon as I turned it off, my gas pedal didn't work and I could not rev my engine. My engine was rattling like crazy, felt like it was going to stall. A couple weeks ago, it happened the same way, but it felt like power loss when I accelerate. I just changed the spark plugs, and cleaned my K&N filter and changed cabin filter. I don't think it has anything to do with it though. Anyone have any ideas? I need your help before I take it to a shop and waste $$$.
Old May 5, 2010 | 10:49 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Does the car move at all?
Old May 5, 2010 | 10:51 PM
Andrew149's Avatar
we need to know the year the 2000-2001 was electronic gas pedals
Old May 6, 2010 | 08:41 AM
dragonrage's Avatar
Codes?
Old May 6, 2010 | 10:56 AM
hiwords's Avatar
you say you cleaned your K&N filter, did you use the K&N cleaner? if so it's probably a dirty MAF. you need to use electronic cleaner spray or they make a MAF cleaner spray.
Old May 6, 2010 | 06:25 PM
10kRedline's Avatar
my car's a 1999.5, the car drives normally now, but might happen again, since this is the second time. but when it happened, the car won't move because the gas pedel won't work and won't rev the engine. I also cleaned it with the K&N restore kit. MAF seems to be clean and ok.
Old May 6, 2010 | 06:29 PM
dragonrage's Avatar
Scan for codes even if you don't have a CEL.
petroprosciutto
Sep 21, 2012 03:33 PM
amwald
Aug 30, 2012 12:01 AM
Jaokaos
Jun 27, 2012 02:18 PM
ps8611
Dec 18, 2011 07:51 AM
mikedento
May 30, 2011 07:02 PM
